Removed true dual exhaust
I had the idea that true dual exhaust was going to suit the needs of my new motor better. But with the lowered suspension and wanting the full 3" duals over the axle.....there just wasn't enough room. I'm going with a forged 383 motor pushing more boost from the ProCharger (hopefully about 12 lbs). I've now switched to a kook's catted y-pipe and went back to my old borla cat back. Much cleaner and definitely more room. I've got a custom 3" duals for sale btw.
Pics of 3" duals installed
Now with Kook's y-pipe and borla
What cats are you using?
I want to switch to true duals because I'm tired of the rasp I get with my GMMG. Sucks that there isn't enough room to get the 3" pipes over the axle though.
Magnaflow cats. The "mufflers" on this setup are Sweet Thunder. I thought about redoing the portion over the axle to 2.5" but it would still have the issues with clearence underneath anyway. Is your car lowered? If not, this will fit better on yours than mine.
I never fired the motor with those on, so I don't know exactly how they sound. These have been built for other guys locally and they sounded good. Fairly quiet at idle, then gets real loud in upper rpms.
I'm on Eibach Pro-kit. The duals are tucked up as tight as can be, but the cat is lower than the cross-member. Also the portion of the tubing by the differential, is even lower than that. It needed to be low so when I jack the car up, the rearend doesn't sit on the exhaust. Then over the axle is extremely tight, rattling is inevitable. I also have the spohn torque arm with the flat bar (for clearance). The duals sat on top of the cross-bar and will rattle there too. It's just not how I want things to be, I thought about going to a 4" system but not many choices there. Seems like alot of members use a 3" and borla with FI and are seemingly happy with it. From what I've been told, unless you're into the 800 rwhp or above....a good 3" system works just fine. So that's what I'm hoping. Plus the 3" alleviates all the scraping and rattling issues for my situation. For the most part.
I've looked into those before. I've never seen them actually in use to know they provide enough clearance for sure. Part of the problem too is the size of the rear. I haven't decided which one I'm going with yet.
In hind-site I was thinking about going to 2.5" just for "over the axle". So having a 3" for most of the system, then squeezing it down a bit to fit better in the tight areas. Just a thought.
