Gears & Axles - Rear end crooked?
EvilCamaroSS
03-10-2008, 10:37 AM
yea so my rear end is...crooked, it's tilted slightly to the right... how does one go about fixing this? or should i just leave it alone?
connexion2005
03-10-2008, 10:43 AM
Like when your at the back of the car it looks like that? Can you take a pic?
I would check all the suspension underneath and in particular the springs and shocks first. Then check little things like the lca's, panhard bar and sway bar.
EvilCamaroSS
03-10-2008, 10:46 AM
new shocks about 5K ago. springs are oem but there ok, i'll try to snap a pic i heard this was a fairly common problem?
97badass
03-10-2008, 11:02 AM
as in your rear wheels sit like / /
or just off center from the car?
EvilCamaroSS
03-10-2008, 11:06 AM
def off center from the car, not so sure on the / /
97badass
03-10-2008, 11:14 AM
has it been lowered? the only cure to fix that would be an adjustable panhard bar my right tire sticks out 1 3/4 inches more than my left. looks silly imo but thats the cure is an adj. panhard to make it shorter so it pulls the rearend back under the car
Blu99T/A
03-10-2008, 11:15 AM
Measure from wheel center to wheel center (front to back). If it is off, which isn't uncommon if it is, adj lower control arms will fix it. If it is off from side to side, get and adj panhard bar and center it back up. Let me know if you need any more explaining of what I described. :)
EvilCamaroSS
03-10-2008, 11:19 AM
Yes thanks for the info! that sounds like the solution to my problem, i wonder what caused it in the first place?
Fran D
03-11-2008, 08:44 AM
... i wonder what caused it in the first place?
GM manufacturing tolerances...at least, that was the case for me.
EvilCamaroSS
03-25-2008, 09:14 AM
I think this could be the reason why my car handles like garbage. We'll see, I ordered new tires, and i'm gonna order these suspension parts as well.
A lot of these rears sit off to the right by .5 inch and they also sit towards the rear the same amount. It really becomes noticeable when you stick a 28" tall tire under there. An adjustable pan hard bar for side to side, and adjustable lower control arm bars for front to rear, are what is needed. Bob
EvilCamaroSS
03-26-2008, 10:37 AM
mine is def off by more than 1/2 inch lol prolly more like 2 or 3 lol, although my tires look centered in the wheel well.
supernaturalta
03-26-2008, 10:51 AM
The best way to go would be to get adjustable rear lower control arms and panhard bar. Then take your car to an alignment shop and ask them to do a 4 wheel alignment. That way it will really be centered instead of just "eyeballing it".
