Which timing chain???
Old 03-10-2008, 02:20 PM
dannyz's Avatar
Default Which timing chain???
Putting in my cam, and I know I need the LS2 timing chain but ther are two types.
There's a single row and a double row.
I have a GM Hotcam so I am thinking the single row is the one I want.
Am I right?
Old 03-10-2008, 02:43 PM
99ssleeper's Avatar
The single row LS2 is plenty and you can use your stock sprockets. Just buy the chain itself from sdpc2000.com.....it's $37 and more heavy duty than the LS1 chain.
Old 03-10-2008, 02:47 PM
98RedBird's Avatar
Another vote for LS2, it's perfectly sufficient for most applications.
Old 03-10-2008, 03:00 PM
bjamick's Avatar
you need the 05 model LS2.
Old 03-10-2008, 03:02 PM
LS1Silverado05's Avatar
LS2
Old 03-10-2008, 05:18 PM
vettenuts's Avatar
If you degree the cam, you will need new sprockets as well.
Old 03-10-2008, 05:23 PM
Blk97WS6's Avatar
like everyone already said. The single LS2 is fine.
Old 03-10-2008, 05:33 PM
sevenstarsfall's Avatar
Anyone know what the LS2 is rated to?? For example what power levels should you step up to a beefier chain?? Im getting ready to do a cam swap or possibly a H/C/I swap soon, thx
Old 03-10-2008, 05:34 PM
forcd ind's Avatar
trust me, if i was starting over, i would go single roller, like others said
Old 03-10-2008, 07:03 PM
vettenuts's Avatar
Not really a function of hp, it really comes down to valve train loads.
Old 03-12-2008, 02:38 AM
LilJayV10's Avatar
So a LS2 single chain would work on a 2000 LS1?
Thanks.
Old 03-13-2008, 12:14 AM
dannyz's Avatar
Thanks for the info guys.
Old 03-13-2008, 01:44 AM
LilJayV10's Avatar
Is that the right part number?
Old 03-13-2008, 03:07 AM
So a more aggressive lobe/cam is gonna need a double roller??
Old 03-13-2008, 04:48 AM
El_Diablo's Avatar
^Hope not. I've been beating the hell out of my stock ls1 timing chain with a TRex/dual valvesprings. Not that I'm knocking anyone, because I don't know, but it seems to me like a very clever individual started marketing cam swap "kits." My stock 01 oil pump is still rockin 50+ psi at idle.
Old 03-13-2008, 04:56 AM
I figure the beefier parts are not always neccessary but more for extra insurance.....
Old 03-13-2008, 11:22 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
12586482
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 03-13-2008, 06:00 PM
MrElectric03's Avatar
Im going with a new LS2 set from Scoggin Dickey....it just makes me feel better putting new sprockets on with a new chain.
Old 03-14-2008, 05:08 AM
vettenuts's Avatar
If you are going to swap it out, why not just get a timing set with a Torrington bearing, that is worth the effort to reduce wear on the cam plate which can increase with more valve train load.
Old 03-14-2008, 07:18 PM
1Topgun's Avatar
Would a GMPP LS6 crate motor-long block, with a July 2005 build date have the heavier (LS2) timing chain? I'll be assembling the bolt-on parts to install it in my Suburban in a few weeks, but didn't plan on replacing or upgrading any internals. Thanks for any info.
