Built LS1 burning oil?
Old 03-10-2008, 06:20 PM
danny03cobra's Avatar
Default Built LS1 burning oil?
Hey guys i am looking into buying a biult ls1 vette and i was told the motor uses 1 quart of oil every 3,000 miles, is this normal?
also compression on all cilinders is 143-155 is this low?
Thanks guys.
Old 03-10-2008, 06:41 PM
can i get some help guys?
Old 03-10-2008, 06:54 PM
brad8266's Avatar
150 is a bit low I believe, might want to try a leakdown test too see the percentage loss and it will tell you where the compression loss is coming from.
1 qt every 300 miles isnt very bad for ls1's though. See if you can find out if the oil is being sucked through the PCV or is dripping down into the chamber through the head (rocker arm hole, valve seal).
Old 03-10-2008, 06:57 PM
The vette has a cam and forged internals, but one cilinder is at 143.
i will ask where exactly the ail is going.
Old 03-10-2008, 06:59 PM
brad8266's Avatar
Ok since its cammed those compression numbers should be ok.
Old 03-10-2008, 07:03 PM
cool, so its pretty common for built ls1 motor to use oil?
also the cam reduces the cilinder pressure?
Thanks for the help.
Old 03-10-2008, 07:11 PM
SOMbitch's Avatar
GM says a quart every thousand miles I believe is acceptable for warranty purposes. When I read this I couldn't believe that much oil use was "acceptable" I bought my 99 Z71 in 02 with 78K and it used a quart every 1500-2000 miles. It now has 176K and still uses a quart every 1500-2000 miles. Pull the plugs and read them and check for wet tailpipes. If it doesn't have the updated PCV valve that can cause oil burning isses too.
Old 03-10-2008, 07:13 PM
cool thanks guys, i was getting worried for a minute.
Old 03-11-2008, 10:39 PM
Hey guys, i might treade my 03 cobra with 20k in mods for this, what do you guys think?
http://pages.villagephotos.com/page.asp?page_id=4051
