Codes
Codes
Posted in the General forum as well. Car is 01 WS6 stock except for lid. Car is throwing po305 (misfire) and po430 (cats/I think). Help with diagnosing the issue?? Tune-up and replace plugs and wires? Someone direct me in the proper direction!!
That is right. And there is a Sticky at the top of this section that tells all about the codes. I would pay attention to the misfire code first and change the plugs and wires. The misfire may very well be causing the second code too. Once the engine is running on all cylinders the emissions code may go away.
But aside from the light the car continues to run just fine, it won't make it miss or loose power or anything.
A flashing SES light indicates a serious engine mis-fire. You have a problem in #5 cyclinder. Like stated above.
