valve spring swap
Old 03-10-2008, 08:59 PM
blue99fbody's Avatar
Default valve spring swap
i have been doing my cam swap and im changing the springs and im having problems with the keepers not letting go of the valves as i compress them, its wanting to open the valves, i am using air to hold the valves up. i have to compress them and hit the retainers to get them to release, and some of them are being a b*tch. anyone have any suggestions or tricks to get them to release eaiser. i am using the crane tool also if you need to know.
Old 03-10-2008, 09:20 PM
kwiksilverz28's Avatar
Hit them with a rubber mallet before you put the tool on.
Old 03-10-2008, 09:21 PM
99ssleeper's Avatar
^ x2...
Old 03-10-2008, 09:25 PM
doing that they are just being stubborn i have one side done just taking some time
Old 03-10-2008, 10:02 PM
Restricted User
socmguy's Avatar
put some magnetic retrievers on those keys or you'll never see them again.
Old 03-10-2008, 10:07 PM
A_VAS's Avatar
try a socket that fits over the valve stem tip, and rests on the retainer. whack w/ mallet.
Old 03-10-2008, 10:31 PM
StreetLethal01's Avatar
I usually use a socket and hammer. good luck
