Nitrous Oxide - Anyone running zex direct port on fast intake with fairly high boost 15 psi or so?
MY99TAWS6
03-10-2008, 09:11 PM
I am going to be running likely around 15psi and was wanting to add direct port nitrous and run small shot also. I am a bit worried about boost leaking out the nozzles on the zex direct port with fast intake. Anyone running this with boost? I am not worried about the fast intake they have taken around 20psi no problem. Just not sure the nozzles will seal well under boost as the intake is not metal. Maybe I am just being paranoid.
landonew
03-13-2008, 08:58 AM
I would also like to know this. If it is a small shot, why not just run a simple dry shot?
Nitro Dave's Nitrous Outlet
03-14-2008, 10:23 AM
I do not see any reason why the boost would leak out if plumbed correctly. How much do you plan to spray though? If you are only looking to spray 50-75 hp to cool the intake charge installing a directport is not really something you need.
Dave
MY99TAWS6
03-14-2008, 10:42 AM
Well could run higher shots as have fully forged engine ,clutch would likely be more the limiting factor and fuel system. Fuel system that likely will get is good to 1000rwhp supposedly so thats 850rwhp on turbos and 150 rwhp shot. Part of the reason for spray is it works well with turbos.Part of the reason is intimidation and show factors.
And intake is ready for the direct port being fast intake.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
