Can someone explain gms/cyl?
Old 07-21-2003, 08:48 PM
98TAauto's Avatar
Default Can someone explain gms/cyl?
how do you know what gms/cyl the car is in via rpms? I see a few of the tables on edit with these and where alot of guys mess with .6 and down for WOT?
but question is, how do you determine what gms/cyl(cells) the car uses for certain rpms?
which gms/cyl is the car in say for cruising 1600-2400rpms? Then which for WOT throttle?
Old 07-21-2003, 09:11 PM
Moderator
JNorris's Avatar
Default Re: Can someone explain gms/cyl?
HD,
Grams per cylinder is a calculated value.
Gms/cly = MAF flow (g/sec) * 15 / RPM
John
Old 07-21-2003, 10:39 PM
98TAauto's Avatar
got it.. thanks alot man
