Fast Setup??????
Fast Setup??????
I have a FAST 78 setup and having a hard time getting the car to idle. HP tuners is showing the FAST TB not closing all the way...showing 5% to 7% open at times. Anyone ever have this problem and if so, what did you do to fix it.
FAST TBs are notorious for sticking open. Hanging idle and all around sucktitude. There is a minority that have not had any problems, but most have. If you're dead set on using the FAST, you can purchase a stronger return spring and rig it up to your Throttle Body Arm to close it shut. Honestly, I would just get a new TB. I am unsure what will bolt to a 78MM though. If it were a FAST 90, I'd say go Nick Williams and never look back.
