Help Please:'(
Help Please:'(
one thing after another so far this season
2 nights ago. trq. arm top bolt comes out
last night, heater hose below(red) cracks(yellow) and soaks every thing!!!!.
now the car starts a lil harder then befor. has to crank about 4 or 5 times more then it usualy did befor. it idles like it has a pretty lumpy cam..witch would be great if it did...but it dosent. its stock. give it any gas and it stumbles all the way upto the rpm you request..it will hold rpms but backfires and makes a really nice "puffing" noise out the exhaust. the cat reaks, and it has no power...whats the next thing i get to invest into ...
Now that I think about it... I had that same problem that you are having. Car stumbling put it in gear and it sounds like shotguns going off under the car. If this sounds like something that you are experiencing, then it’s your opti spark. im almost certain that it will be. It’s not to hard to change out, keep us up dated on what you find man!
next question, kinda related...am i able to drive the car well is like this?? i need to drain the A/C system some how *inless i can do it at home witch would be awasome*
