HELP Ticking Noise!!!!
I have this ticking noise and i dont know what it is!!! my mods are in my sig. this noise is not a exsaust leak! the first time i got rid of the noise i had a loose rocker, then 3 weeks later it did it agian i thought it got loose agian, nope every rocker was tight i took off the ffirst 3 and put lock tight on them and the ticking noise is still there!!!!!! this is all on the drivers side. please help!!! thanks!!
Re: HELP Ticking Noise!!!!
Did you check the belt and pulleys? One of my pulleys makes a funny ticking sound when the car is cold. But it goes away after it warms up. At first I thought it was one of the rockers, but it's not. I haven't looked too much into it yet. If if gets worse, I will...
well its not a bent push rod, its been doing it for awhile, but at 1 time i got rid of it, then it came back, also not a spun bearing, runs to good. thanks for the help
Under what conditions does the noise occur? Can you tell the area where it is coming from? It could be a number of things. Have you touched the oil pump at all? If so, It could be related the the pick up tube O-ring. I had that problem a couple months ago.
Matt
Matt
I realize you said you don't think its an exhaust leak, but do you still have your AIR system on your car? In particular your AIR tubes? You might have a burnt check valve. A lot of times when the check valve goes they make a ticking noise.
A new check valve and the AIR restrictor mod will take care of it.
