Twin remote mounts and crossover
I am doing a twin, remote mount turbo setup. The turbos are about 2.5 feet from the collector.
I have one back going from collector, into turbo. Same with the other.
I generally understand the concept of the use of a crossover pipe in N/A applications. But what about turbos, specifically a twin semi-remote setup? Do you still do a cross over, and if so, before the hot inlet of after?
Jeff
Jeff
I think I understand. So because of the compressor pressure (ie, turbo application) it will balance anyways.
So if I go engine, exhaust headers to turbo inlet, then turbo exhaust outlet, straight out the back (2 separate exhaust tubes, one for each turbo), I should be ok?
Thanks,
Jeff
Thanks,
Jeff
