Clutch Swap
Old 03-13-2008, 04:57 PM
PEZ97T/A's Avatar
Default Clutch Swap
i Read the sticky above and at the end it said bleed hydros how do i do that?
Old 03-13-2008, 05:11 PM
hndakilr's Avatar
mity vac is a good retard proof tool
Old 03-13-2008, 05:19 PM
PEZ97T/A's Avatar
im saying like what do i do with your "mity Vac" lol. where does it go and stuff. this is my first time doin this.
Old 03-14-2008, 12:06 AM
hndakilr's Avatar
check out the sticking clutch sticky.
Old 03-14-2008, 12:10 AM
hndakilr's Avatar
or... put your finger above the master cylinder line going into the trans. run your finger up the trans until you can feel the hex screw on top of the trans. you have to bleed it by feel and you will need somebody to hold down the clutch while you crack the screw. thats why drilling the hole in the floorboard is the easy way. nobody will ever know its there.
