Notices
I need SMOG equipment off a LS1
Old 03-13-2008, 07:59 PM
sirshan's Avatar
Default I need SMOG equipment off a LS1
Let me know if you have the following:
Ill buy whatever it is you have...
1. Air tube+ check valve (right and left or 1 & 2)
2. Air pump shut off valve + hoses that go to the air tube/check valves
3. the tube from the p/s header to egr valve. the egr bracket that bolts to head. you already have the egr.
4. Evap canister
5. Evap purge valve and solonoid
6. Evap vent valve and solonoid
7. Evap service port and hose
8. Fuel tank pressure sensor
9. Secondary air bleed valve
10. all hoses that go to evap canister
-evap vapor pipe
-vent hose pipe
-evap purge pipe
Old 03-14-2008, 04:55 AM
AF1Bird's Avatar
I have air pump and hoses from 98 T/A ready to ship. PM me if interested. Thanks.
Old 03-14-2008, 01:55 PM
Krab's Avatar
I have complete AIR and EGR assemblies off my '00 SS. Shoot me a PM if interested.
Old 03-15-2008, 12:43 PM
sirshan's Avatar
UPDATED LIST.
My car is a 2002 Motor....
1.EVAP canister
2.EVAP purge valve and solonoid
3. EVAP vent valve and solonoid
4.EVAP service port and hose
5.Fuel tank pressure sensor
6.Secondary air bleed valve
7. all hoses to evap canister
-evap vapor pipe, vent hose pipe, evap purge pipe
Old 10-27-2010, 03:34 PM
04GTOintoRX&'s Avatar
Default 1990 Mazda RX7 FC3S LS1 Swapped CA BAR'd T56 2002 Motor
Hi
Just saw images of complete car and in the process of converting one myself. I don't quite understand the CA smog process I think I have done most of the work but when i called the ref. he tells me I need to incorporate the Pontiac GTO gas tank into my 1990 RX7. My question to you is, do I really need the Gas tank swapped. And where did you place the charcoal canister? I see you also used the radiator provided by the Granny's what radiator hose did you use at the bottom cause the one I have is almost up against my AC compressor and very close to rubbing. I am also using Auto meter gauges and I was wondering if I cut out the holes into the existing Mazda RX-7 instrument cluster would indicator lights, fuel level sensor and the other gauges work. You also have a new water hose tap into the radiator right below the out flow hose from the engine, what is that for?
Thanks for taking the time to post info about your project. It is sad to hear that you had to sell it after all that work.
Thanks
BM
Quick Reply: I need SMOG equipment off a LS1
