View Full Version : nitrous hits slow??
dameter21
03-13-2008, 09:01 PM
I've been spraying a 100 dry shot fine as of recently it seems to not hit instant like it used instead it comes into play like 2-3 seconds. And its activated by WOT switch. what could be problem..
2000Hawk
03-13-2008, 10:46 PM
Do you have a purge kit, maybe you got air trapped in the line thats why it doesn't have that initial hit. If you do, where is your bottle pressure at as well?
-Joel
BobDoLe
03-14-2008, 05:25 AM
what happens in that 2-3 seconds, does it hit hard after a 2-3 second pause, or is it just not hitting hard at all?
check for kinks in the line. are you using the spray bar by any chance?
Chris@NitroDaves
03-14-2008, 09:32 AM
-Joel
What he said and How do you have your nozzle mounted?
-Chris
dameter21
03-14-2008, 05:46 PM
full bottle no kinks I zip tied the shit out of feed line,nozzle mounted on lid about 6 inches from maf pointing in the right direction on the inside, I'm stumped.
SlayerMaro
03-14-2008, 09:15 PM
You still didn't answer if you had a purge kit or not, though. That could be it.
dameter21
03-14-2008, 11:00 PM
no i don't have a purge.. isn't there a way you can manually purge the line i heard that somewhere, I've always had purges kits except this car.
MeanWS6
03-15-2008, 12:31 AM
purge kit = problem solved
