Another pulley question??? Need Help
Well I will be done with my cam change this weekend. Going to have have the car tuned in the next week or so. I would like the car to make between 8-10 pounds of boost. My car has the D1SC on it. The S/C has a 3.70 pulley on it now. Car shows making 4-5 pounds of boost now. I believe mine is 6 rib. After I get home I will post which one it is.
Which pulley do I need to achieve the boost I want?
Which belt for it?
Where to buy the tensioner pulley? Mine is worn out.
Any help will be appreciated.
Thanks,
SBP
Which belt for it?
Thanks,
SBP
It sounds like you have the 6 rib pulley assembly, which is equipped with a much smaller crank blower pulley. With no coffee yet this morning, I'm thinking it is 7.0 in diameter. I just heard the other day that ASP makes a 8" diameter crank pulley for the six rib kit, which combined with a 4.75 to a 5.00 blower pulley would give you the boost you're looking for. Bob
Can't find any other setups online. Maybe not looking in the rite place. Does the SDCE have a website? Not sure what company that is.
Also what company is ASP? Tried calling Procharger today, but the guy I spoke with wasn't much help. He wanted the part number of the kit installed on the car. It was on it when I got it. So not much help from them.
Thanks,
SBP
Thanks,
SBP
http://www.exoticperformanceplus.com....html?item=716
You will also need this balancer and pinning kit.
http://www.exoticperformanceplus.com....html?item=455
http://www.exoticperformanceplus.com....html?item=458
To make between 8 to 10 psi you're probably need a 4.25 blower pulley with the eight rib kit. Bob
yes you do have to send it in, but if there close in price I would go with the sdce setup, its been proven over and over again (by me too) to eliminate belt slip at high boost levels. also Bob and his crew have come up with some pretty slick methods as well over the last few years. I would give him a call and see what he suggests. maybe they can figure out the f body 12 rib dilemma. that would be cool to
