480E in a 2500hd whines in 1st gear Need help
Old 03-14-2008, 01:39 PM
NovaCain383's Avatar
Unhappy 480E in a 2500hd whines in 1st gear Need help
I have a 05 Chevrolet 2500hd with a 6.0 gas engine. When the truck is in 1st gear, it has a loud whine. It goes away once it shifts to 2nd and all other gears. Is this normal or something that should be fixed? The dealer said they could put new planetaries in it but there is a chance it will still whine. Is this something I should have them fix? Since it is doing this will it cause it to fail in the future? Seems like it has gotten louder since I have had it. Any help will be appreciated.
Thanks,
SBP
Old 03-14-2008, 02:15 PM
Gilbert@Ace Racing's Avatar
It could easily be an oiling issue such as a partially clogged cooler. It might be wise to check the cooler flow.
If it has spur or straight cut planets they will be noisy. Some factory HD units were equipped with them.
g
Old 03-14-2008, 03:10 PM
RamAir02TA77's Avatar
Ive heard its pretty much normal. My 4l80e does the same thing.
Old 03-14-2008, 03:12 PM
cablebandit's Avatar
mine too
Old 03-16-2008, 09:28 PM
the big d's Avatar
mine doesn't
Old 03-16-2008, 09:46 PM
LS1Tech Sponsor
performabuilt's Avatar
They do this in variying degrees, And some even have a damper ring on the rear planet to help prevent it, While I cant say the OP has no issue without hearing it. I wouldcheck cooler flow and if all is good there I would not worry about it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-16-2008, 11:20 PM
01WS6/tamu's Avatar
If it's the humm or whirr as it sounds in my truck it has been doing it for 345K with no ill effects. Don't sweat it. I take it this is probably a truck you just bought.
Old 03-17-2008, 05:36 PM
I have had the truck for over year. But seems I notice it more now than ever. Also has the sound on real cold days as soon as it starts.
SBP
Quick Reply: 480E in a 2500hd whines in 1st gear Need help
