do i NEED to change my shock mounts out when i change my springs and shocks?
Old 03-14-2008, 02:06 PM
CaMaRo67RS355's Avatar
Question do i NEED to change my shock mounts out when i change my springs and shocks?
just bought new qa1's all the way around and was wondering should i get new shock mounts?
Old 03-14-2008, 03:21 PM
z28bryan's Avatar
No, I have my original stock mounts with konis/stranos
Old 03-14-2008, 06:49 PM
hpjunky98's Avatar
Same here
Old 03-14-2008, 08:14 PM
wowsers's Avatar
im going to change the strut mounts whenever i get around to installing some new shocks/springs. its not necessary but they can wear out and start squeeking. i guess it just depends on how many miles you have, and whether or not you want to spend another $100
Old 04-11-2008, 10:56 PM
Beat98TJ's Avatar
I assume you mean the upper front shock isolator assembly. I have had to replace a few generally on high mileage cars where corrosion becomes an issue. Otherwise you should be fine. If the car is a dd and you live in any kind of corrosive enviroment put some antisieze on the shock tenon where it goes into the isolator.
