Bad Starter again
Bad Starter again
I swear I have zero luck with starters, the car does this randomly, but when you turn the key, you get nothing, starter is dead. Then eventually you turn it enough, it will crank and then start up. It could go a few weeks and never do this again. So far its always started just gotta turn the key a bunch of time, battery is always left on maintainer to retain charge. The car used to do this when an old starter I had went bad a few years ago, but it was only when the car was hot. Now it does randomly, I can see the volt gauge move when I try and crank it, so power is going some where. Just seems like the symptoms of a starter going out. Only other thing I could think is maybe an ignition switch, but I can see the volt gauge move, the cars sending power to try and start, the starter isn't either getting it or not working.
I have been having this same exact problem on my LT1 thirdgen. I thought maybe it was because the starter was so dirty from oil. I haven't figured out this problem yet, as it is stored currently and I haven't put the starter back on yet. I will be taking it out soon, though, and will report anything if I find anything out.
I busted out the trusty service manual, its either a bad ignition switch or a battery issue. Just have to wait for it to do it again so I can follow the trouble shooting. Its looks more and more like a electrical issue then a ignition switch. Your suppose to watch what the lamps do when you turn the key and go from there.
