Pontiac GTO 2004-2006 - Gto Stock 1/4 Mile Times Are?
BlueBandit
03-14-2008, 04:41 PM
stock times for 04 gto automatic.. times jump from 12.9 to 14.0.. can someone give a honest answer?
Blackhawk777
03-14-2008, 05:32 PM
An 04 gto can usually hit a quarter in around 13.3 with an average driver. High 12s with the driver mod.
Smo's04Gto
03-14-2008, 06:09 PM
Do a search over on ls1gto.com
ExTurbo
03-14-2008, 07:52 PM
average drivers are getting mid-low 13's, great drivers are getting high 12's. Depending on how well your car is prepped what tires your using, track temperatures, your driving ability...the factors go on and on, ultimately you gotto take it there to find out!
TORNATIC!!
03-14-2008, 10:15 PM
I have a modded '04 GTO A4. A stock '04 GTO A4 will run low 14s/high 13's on average. Heat soak and torque management are big reasons why people struggle to get out of the 14's in them. Just a tune wakes them up big time. I dropped a few tenths and gained a few mph just off a (custom) Predator Tune.
KrautBurner
03-14-2008, 11:35 PM
I'm pretty sure "nobody" with a stock 2004 a4 has broken into the 12's
Edit:
http://ls2gto.com/forums/showthread.php?t=200157
LS1 Stock class:
1) Nutiger 13.025 @ 108.31
2) H82BSLOGTO 13.09 @ 105.00 MPH
3) ls1gto 13.10 @ 107.3 MPH
4) TRU GTO 13.136 @ 105.76 MPH
5) GTwhoa 13.15 @ 105.35 MPH
6) nutiger 13.245 @ 104.86 MPH
7) GTONEWB 13.248 105.99 MPH
8) slammin86 13.27 @ 105.46 MPH
9) nikivee 13.3 @ 104.00 MPH
10) 1meangoat 13.307 @ 104.61 MPH
11) Nmbr1GMfan 13.390 @ 104.54 MPH
12) win98nogood 13.393 @ 105.10 MPH
this list is A4/M6 combined
98REDZ
03-14-2008, 11:39 PM
yeah i've seen one run consistent 14's numerous different days out at the track
GTO8522
03-16-2008, 01:22 AM
driver mod?yeah i've seen one run consistent 14's numerous different days out at the track
Texas Heat
03-16-2008, 03:20 AM
Umm no way in hell 12's in a stock ls1 goat, I even highly doubt low 13's from every one of them I have seen run!
A4 LS1 GTO's aren't that fast compared to the others. Best I've seen was 13.4. 13.6 on up is probably closer to average.
M6 LS1 GTO's run better :)
GTO1_OHIO
03-16-2008, 04:42 PM
New driver stock A4 04 will be high 13's - low 14s. ...you can count on that. Now as for the low 13 sec's that stock 04s have gotten to date ... there's a combination of reasons for those low stock times. These are really cold temperatures with a very negative DA, running at a track like ATCO (at about sea level), and major weight deduction (pulling out back and passenger seats + other typical things). That being said, under "normal" conditions at tracks across the country mid 13s would be a reasonable goal.
the big d
03-16-2008, 10:22 PM
ran 14.30's all day in an 04 a4
ran a pass right after a 35 mile drive and got lapped it for 5 runs
PapaSmurf2005
03-16-2008, 11:30 PM
High 14's to mid-high 13's. No one has got one in the 12's fully stock.
great421
03-16-2008, 11:35 PM
My brother's 100% stock (stock air filter / stock tires!) Plum Crazy Purple Goat ran 13.8 at Lapeer (MI) dragway all day long with the Traction control OFF (14.1 with it ON) in 60 degree air.
ArklaTexan
03-17-2008, 09:39 AM
Hell I still rund 13's once in a while when I miss a shift :D Before I was modded my best time was a 13.7 with a 1.8 60ft
Kyle D98
03-17-2008, 06:58 PM
Theres no way a 2004 gto with an ls1 an auto can get mid to low 13's. I have an ls1 A4 camaro and its a mid 13 car with intake and exhaust, a heavier gto with more power will not beat that time. High 13's maybe a 13.6 with an auto ls1 gto is possible.
goat-ee
03-18-2008, 03:52 PM
Times and minimal mods in signature. Maybe better this year as the times are traction limited and I am replacing the tires with some drag radials and cool spring air. Mid 13.5's are very doable and with essentially just a Diablo tune and air intake mods I am very happy. Yes I know I have a catback, it did NOTHING for performance. The best money I spent was the $167 shipped I paid for the DiabloSport on eBay and then the customized tune was free. Tweaked the tune with some help of the guys on LS1GTO.com and I have proved to myself on two separate occasions that the tune and accompanying better A4 shifting made a 4-6 mph and .4-.6 E.T. difference.
Our cars are tuned like crap from the factory, so spend the money like I did or if you don't want to do it yourself pay for a dynotune for probably even better increases. My A4 car is a different car with the tune.
SSkillz
03-22-2008, 08:27 PM
I ran a 13.5 in my bone stock gto M6
KrautBurner
03-23-2008, 02:03 AM
carefull what you say
Theres no way a ....
just cause you can't do it, dosn't mean someone else can't
you never know....
I've been told "theres no way..." :
- a stock gto clutch will hold 500hp (I've got 44K miles on mine, over 500rwhp/600rwtq)
- a M6 GTO will cut under 2.0 60' with stock tires (I cut 1.86 a few times)
- a M6 GTO will cut under 1.8x 60' with Radial tires (I cut a 1.55 60' and a bunch of 4.6' 60' times with mine on M/T DR's)
my gto is heavier and has more power, :devil:
I ran 13.2 bone stock
and my car is still heavier, and still has more power
and i run mid 11's :secret2:
:werd:
I was told when I bought mine that it wouldn't even get out of the 14's. Very first pass with a few hundred miles on the clock was a 13.6 and whittled that down to a 13.2. Then mods started and low 12's with a car that sounded completely stock that everybody thought I had a bottle hidden somewhere.
It can and has been done...
harlesjohn
03-25-2008, 07:26 PM
i ran a 13.7 on street tires with 1/4 throttle threw 1st, 2nd and had to baby shift into 2nd and 3rd..
wheel hop was my issue..
should be gone now that i have mazda mpv air bags for the back.. i hope to see very low 13s and maybe break a record..
BAADGOAT
03-27-2008, 07:09 PM
I ran a 13.29 @ 105 w/ a 1.93 short time on street tires stock...M6 though...
quadd2244
03-31-2008, 12:32 PM
Theres a small thread right now over on LS1go that the quickest bone stock GTO went a 12.76 or something. Needless to say I raised the bullshit flag. The quickest bone stoc fbody I think was a little slower then that and come on the Fbody has more power from the live axle and weighs ALOT less.
quadd2244
03-31-2008, 12:33 PM
THANK YOU!!!!!!:chug:
regblkss
03-31-2008, 01:46 PM
my wifes 04 a4 gto stock with just a kn cold air kit and spare tire out stock rubber run a 13.5 at 104.
yellowjacket48
04-01-2008, 12:19 PM
Well I better chime in and ask what you all think I can run with headers, exhaust, intake, p&p throttle body, 3000 stall, and a tune? Oh and drag radials as well.
rwehberg
04-01-2008, 08:15 PM
i had a 04 gto and my best was a 13.4 @ 103 that was bone stock no way there hittin 12's bone stock
blkbltgoat
04-02-2008, 12:17 AM
why are you taking this so personal. i think you have posted more comments on this topic then i EVER have. its like a 04 gto in the 12s would mean you gonna die. let it go and move on with your life buddy.
thatboyvic
04-05-2008, 10:56 AM
fully stock off the lot 13.3 @ 107
an 06 gto can get into the twelves stock... most of the fbodys do all thier free mods first...lol i was pulling enough mph to blow 12's stock... that was with a 2.2 60ft on street tires... at sar.
at hrp with minor weight reduction and some drag radials it would have busted a 12.9 stock
necrocannibal
04-05-2008, 12:05 PM
LOL you sound like all of the naysayers when f bodies were busting high 12s.
TORNATIC!!
04-06-2008, 05:42 AM
With that I'd say at least high 12's on a cool night. I think I seen a '04 GTO with similar mods run a 12.7 or 12.6 at 108
harlesjohn
04-06-2008, 12:10 PM
im pretty sure i can get into 12s with just a nice 15 inch rim on a 275/50 mt et radial stock..
86MonteSS
04-06-2008, 02:18 PM
my buddy ran a 14.0 in an 06 GTO A4
dgr00s
04-06-2008, 03:08 PM
what did he run after turning off TC or maybe trying again?
nutiger
04-07-2008, 11:31 AM
I've been running my GTO at the track for almost 3yrs now and can say on a cold day at Atco, it will run 12's. An automatic will not run 12's stock since it can't get the RPM's high enough on launch. Low 13's is possible for an A4 car but will need a good street tire. BFG KDWS are not optimal for drag racing but the KDW's will do better.
I only posted my 13.02 run since a lot of people complain about Atco as a cheater track. Can we help it that NJ has great air! I ran a 12.73@108 last Nov/Dec (can't remember exactly). The 13.02 I ran only did a 1.95 60 ft, but with the 12.73 I had a 1.81 60 ft. The trap speed was the same for both runs. I also ran a 12.76. 12.79, 12.85 that day.
The car was stock bit took out the D/S headlight (good for .15/1.5 MPH) and took out the spare tires/jack. The car does have Toyo T1-R tires which hooked great!
During the hot months, the car runs 13.50's-13.70's. Just need to keep the car cool!
patisi
04-07-2008, 07:29 PM
I have an '05 GTO M6 (12.89)@ 109 MPH bone stock, built 3/2005, purchased 7/2005. 28,000 miles on the clock today, bone stock to the paper filter. I am in North LA county, CA. What is so hard to believe? I also own an '04 Cobra that is bone stock as well.
Derek_02z
03-19-2009, 12:50 AM
I dunno where all these people are getting these bone stock times from but low 13's high twelves isnt happening with a stock LS1 Gaot. I think the LS2 goats can probably pull off a low 13 high twelve with a good driver in good air and hooking on good streeet tires. As we all know the GTOs are heavy and just dont run what they were expected too... but i know my 02 camaro with slp lid and stock 3.23s out back will outrun any stock 6.0 or 5.7 GTO. i have did it to 5 or 6 now... so come on guys... high twelves... think logically about it for a second...
DNTMPME
03-19-2009, 07:43 AM
I ran a 13.345@106 with a 2.072 60ft in my stock M6 with full weight and my 220lb a$$ with a 1/2 a tank of gas and it was my first time launching any M6 at the track and I live in Tulsa and we dont have a low DA it's approx 206..... It's all in the driver... I was also running on semi-bald Khumo street tires...
DNTMPME
03-19-2009, 07:48 AM
Bring it on buddy.....
Derek_02z
03-19-2009, 10:54 AM
Ill drive up to tulsa and run you for $500???
$500 dollars says nothing will come of this. :rotflmao:
Derek_02z
03-19-2009, 11:54 AM
Well i hope not... im sure he knows what would happen.
dubrado
03-19-2009, 12:22 PM
I only ran 14.0 stock with 2.0 60ft.
I'm talking paper filter stock.
I think some other people don't mention their drag radials or their intakes. "stock" has a different definition with different people
Also, some of those people with those times are at some of the fastest tracks in the US...where as a lot of us don't live close to tracks like that and have slower times.
RacerXLs1
03-19-2009, 12:35 PM
Im down for a $500 race.. Where are you located at.. No roll racing bullshit.. I love how people come on the gto part of this site. Talking shit.
oshia86
03-19-2009, 12:50 PM
My old Grand Prix with a measly 5.4l has stayed within 1/2 a car from ls1 z28's and trans ams. If you asked me what would win between my GTO and the t/a or z, i'd put my money on the GTO. Love the other cars though, from my experience it doesn't seem like they would keep up.
I guaruntee I would have NO problem coming around your car, and my car is pretty close to stock. (CAI, Tune on street tires)
:D
Shit I have no doubt that I could have done it BONE stock.
And who the fuck with a stock ass car comes at people for money races? :rotflmao:
DNTMPME
03-19-2009, 01:16 PM
No, not really.... Are you doubting that my car ran a 13.345@106?? And yes, It's stock....PAPER FILTER STOCK..... and no, I didn't have DR's either.... Why is it so hard to believe that some one might actually no how to drive???.... I guess some people are just jealous... I tell ya what.... I will beat you for free :D I'll even put my stock shift knob back on...LOL
FryZ71
03-19-2009, 01:44 PM
Apparently the same people who dig up a year old thread, lol.
:rotflmao:
Hahaha, I didn't even notice. I am suprised the guy who he called out saw this thread and responded. :)
RacerXLs1
03-19-2009, 02:16 PM
Wow, I didn't notice either :D
massillongoat
03-19-2009, 04:55 PM
hilarious....I could see low 13s in a m6 i Had a pretty much stock gto all it had was a drop in k and n and it ran a 13.6 at 103.46....and that was at drag way 42 in ohio in july....it all depends where u live...and how good the track prep I could see low 13s but I don't see 12s not in an a4 at least...you'd have to have a tune and some drag radials...
oshia86
03-19-2009, 05:14 PM
Look at the list on ls1gto.com, there are ls2 gto's in the 12's and plenty in very low 13's. I doubt the ls1 will be able to make it to 12's but it sure wont take much for it to.
Insane
03-19-2009, 07:04 PM
A stock LS1 with an auto would need great weather conditions to break the thirteens at Memphis Motorsport Park.
Derek_02z
03-20-2009, 02:19 AM
im in northeastern missouri and for $500 ill meet you half way... and i dont do rolls...dead stop 1/4 mile run on concrete for $500!
Derek_02z
03-20-2009, 02:20 AM
:D
if you werent all the way out in california i would take your money too sir...lol
Derek_02z
03-20-2009, 02:24 AM
ok good for you im glad you ran a 13.30 but thats still no where close to what its gonna take to come around me... and there isnt gonna be any beating me.... so i dont care if its for free... $500...whatever... you better get some drag radials gears and at least a 150 shot before your even gonna be close to me...
KrautBurner
03-20-2009, 03:32 AM
http://www.salagir.com/gfx/troll-web.jpghttp://img3.imageshack.us/img3/5840/925262troll.jpg
I'm a fucking Troll :emb:
GTFO of the GTO section,
nobody wants to hear about your slow ass F-Body:gtfo:http://pics.bikerag.com/Uploads/data/500/258Troll_spray.jpg
KrautBurner
03-20-2009, 03:41 AM
http://enigma.dune.net/~eric/Do-not-feed-the-troll.PNG
Legal Tender
03-20-2009, 08:33 AM
mine would run 14.0 @ 101-102 over and over and over
I agree, with a little better air it MAY have gone 13.x.
but, my goat was a 14 second car from the factory :D
slammin86
03-22-2009, 04:24 PM
I run 12's in my 04 m6. Performance wise I have a flowmaster catback, and a jhp maf pipe.
Oh I also have stock 18's and a PBR BBK. The BBK weighs more than stock.
Allan21
03-22-2009, 04:53 PM
I agree with insane I have seen 04 gto's barley break out of the 14's in memphis. And I have had stock 05 auto that only ran 13.7 bone stock to the filter.
NEARING87
03-22-2009, 06:29 PM
Whats the elevation at Memphis Motorsport Park?
DNTMPME
03-23-2009, 08:39 AM
OHHH! so now you say I need a 150 shot, gears, and DR's????? WTF? I thought you only had like a lid and exhaust??? that must be one of those factory 500hp Camaros.... You got yourself a really rare car.... Who the hell calls out a stock LS1 with one that's modded?:gtfo:
RacerXLs1
03-25-2009, 07:18 PM
Agreed, where can i buy one of those at.:gtfo:
Fatbum
03-26-2009, 05:55 PM
So much misinformation in this thread.....
Those 13.0s are with GREAT drivers at GREAT tracks.
high 13s are common place. VERY common place.
Mid 13s are common ground for both.
Low 13s are common place for 05-06 GTOs.
All being stock of course, down to the tires.
necrocannibal
03-26-2009, 07:26 PM
If you cant pull a low 13 out of an LS2 GTO then you should be driving a Prius.
necrocannibal
03-26-2009, 07:27 PM
Its about 600 ft above sea level.
RocketCutlass
03-27-2009, 12:04 AM
I pulled a 12.6 out of my 06 M6, she's still stock and under warranty.
oshia86
03-27-2009, 12:39 AM
Wow, people really get there panties in a bunch to see a 3800lb car run a good time. FWIW i have not seen a ls2 gto not run a low 13, and havent seen any ls1's run a 14. Hell ive seen a buddy of mine run a 13.1 with after having his goat for 2 days, and by no means is he a great driver. Anything is possible in racing, hell i could take my gto down the track to a 16.0 and a ls1 t/a could run a 13.8, does that make the t/a a faster car...hell no, but it makes him a faster driver.
NEARING87
03-27-2009, 02:09 PM
1+......
Unless the DA is over 2500 or something
NEARING87
03-27-2009, 02:10 PM
Thanks. So it's about the same as SAR.
NEARING87
03-27-2009, 02:20 PM
Well, I'm not a great driver and Richmond is not a great track.
But I had 3 13.0x passes there. one being a 13.00@107.99 3850lbs and a DA around 100.
If you don't let these cars cool off they fall on thier face!
necrocannibal
03-30-2009, 09:23 AM
Man aint that the truth. When my car was still fairly new I wentto the track and ran it as soon as I got there and it went 13.7 @ 104 mph with a 2.2 60', had some bald asss street tires on it.
Let it cool off for over and hour and ran it again to a 13.4 @ 107 mph with the same 60'.
I now have new tires and will be going back soon.
RacerXLs1
03-31-2009, 02:40 PM
I agree...
2001ws6-500hp
04-08-2009, 07:12 PM
compared to what people have been saying this seems low........:secret2:
wonder what hes up to............
goatboymatt
04-09-2009, 12:00 PM
just saw this thread....
Bone stock down to the paper filter with 100 lbs of stereo in the back at 90* weather I ran three runs that night:
13.601
13.621
13.611
DNTMPME
04-13-2009, 04:21 PM
13.601
13.621
13.611
WTF??? I didn't know you could fit 100lbs of stereo back there.... I did fit 480lbs of tube sand in mine during the snow storm...:D
breze84
04-25-2009, 03:21 PM
With my 04 M6, Bone Stock I ran a 13.247 @ 105.7 with a 1.8 60'...... on stock KDW's, main prob with these cars getting good times is traction and heat soak.... Traction more so in the M6, and Heat soak in the A4..... Good driver in a M6 can run low 13's all day.... A4's are dummie proof for the most part, your looking at mid 13's 14 flat without the heat soak factor.... but i also put down 326 RWHP / 338 RWTQ on Modern Muscls Dyno Jet Bone Stock....... i currently put down 361 RWHP / 359 RWTQ
jbs02somws6
04-28-2009, 05:09 PM
Guys I agree about the variations in different tracks around the country. Track prep is just as crucial as weather/temp when trying to get a good time on stock radials. For instance my friend has and 06 gto a4 like me and ran a 14.0 at 99 in July at IRP (indy). It was 90deg and no traction in first. The same night I ran a 13.9 at 102 powershifting my TA with a 2.3 60 time. Anyway my friend with the Goat happened to run a 13.3 @ 105mph later in the year at the Muncie dragstrip off of US 41 with no new mods. I on the other hand run dead even with several high 12 sec cars on the street. I think officials at a lot of these dragstrips don't prep the tracks well on street drag events so people don't hook up and start breaking crap. Anyway, I believe any year gto with any tranny is capable of low 13's, but auto 04's will need low temp and killer traction. This is of course coming from someone who mostly saw low 14's high 13's from all year goats and f-bodys in the summer at IRP. FYI i'm planning on running my stock 06 at the fontana dragway in the next month. I'll post a result then.
dgr00s
04-29-2009, 09:42 AM
Apparently, Car and Driver ran a 12.8 at 110 with an 05 GTO, if they can do it, we should be able to.
70lsgto
08-05-2011, 03:55 PM
I was looking at these espesially the 04 gtos because the prices are coming down but i would hope they would be a little faster.....my all steel 55 chevy bel air went 13.40 with a stock 5.3 out of a truck and a carb bigger car less cubes no cam what happened to progress how come all that gm comes out with is so heavy!!! can the corvette engineers please work their magic on the rest of the fleet?
svede1212
08-05-2011, 10:01 PM
The difference in the WHOLE CAR between an old Bel Aire and the goat is light years and don't forget 25-30 MPG . What did that pig of a Chevy get? The goat is primarily a GT car that happens to run a pretty quick 1/4. You're also comparing a modded car to a stock one. It takes very little to put a LS1 goat into the mid to upper 12s and ride in comfort. An independent suspension car is a different animal and these guys that are getting 14s haven't gotten the knack. Our local track at 925 feet had many '04 in the mid to low 13s stock with 2,000+ DAs.
70lsgto
08-06-2011, 07:07 AM
Yes i see your point about gas milage, and comfort, thanks.
Venomous281
08-13-2011, 12:18 AM
i ran a 13.6 @ 105 fresh off the trailer then it kept getting slower and now i know why due to heat soak. I got the car tuned and i know it should go 12's
WhiteKnight '01
08-13-2011, 12:28 AM
So a stock Camaro/Firebird LS1 can get into the 12's bone stock (very rare of course_ but a stock GTO with the LS1 can't get into the 12's? Same engine...
svede1212
08-13-2011, 09:07 AM
That is correct. Weight difference, IRS, etc is the reason. A stock GTO is fairly rare and is a beautifully appointed car that rides in comfort and a Camaro/Firebird LS1 sounds like a can of loose bolts and the t-tops leak. If someone wanted the fastest stock car they wouldn't pick either one.
BTW I had t-top leaking 2 fBods before the GTO. . .
WhiteKnight '01
08-13-2011, 10:16 PM
My Camaro is my first F-body, and while I have read and heard several accounts that these cars do leak through the T-tops, mine is 10 years old with almost 70,000 miles, T-tops are solid, don't leak at all.
Now on the other side, the weather strip on the driver's side is wearing out, and when the rain is very very heavy, I get about one rain drop in per minute, very minor though, barely worth mentioning.
Yeah, the F-bodies do ride pretty rough, I bet the GTO is a much more refined car. Can't get over how ugly they are though, I don't care how fast it is, it's a hideous car and looks like a cross-breed between a Neon and something else, hideous in my opinion.
svede1212
08-14-2011, 12:58 AM
Boy racer cars are so much better
WhiteKnight '01
08-14-2011, 02:35 AM
The Camaro is commonly referred to as a boy racer car, so is the Vette.
