IRS from caddy on camaro?
Old 03-15-2008, 07:39 AM
dochall22's Avatar
Default IRS from caddy on camaro?
I may be totally off, and just stupid for asking this - but has anyone ever took the IRS from the cts-v and put it on a f-body?
Old 03-15-2008, 08:57 AM
Awake455's Avatar
LOL, interesting idea. Undertake an extensive fabrication project to install an IRS that would give the F-body about the only rear axle setup out there that is weaker than the 10-bolt. Venture to the Caddilac CTS-V section and feast your eyes on the nightmare those guys n gals are enduring with the diff on those things.
Not a stupid idea, just kinda unresearched.
Old 03-15-2008, 09:01 AM
dochall22's Avatar
so what is the benifit of the IRS? I've never even rode in a car with that type of setup, didnt know what the big deal was?
Old 03-15-2008, 09:02 AM
dochall22's Avatar
and my main reason for asking was i have access to a junked out cts with the IRS and i can get it by trading some junk outta my garage for it just didnt know if it would be worth the effort.
Old 03-15-2008, 10:01 AM
BIG_MIKE2005's Avatar
Here is your anwser. It would be unique, but a huge waste of time & money.
Old 03-15-2008, 10:06 AM
dochall22's Avatar
isnt a vette IRS? what about from a vette?
Old 03-15-2008, 10:17 AM
The IRS rears are gonna be weaker no matter what. If you have a f-body you need to just go 12-bolt, 9" or Dana 60. Plain and simple. Anything else is gonna be weaker.
Old 03-15-2008, 10:19 AM
97badass's Avatar
if it can be had for cheap get it and ebay/craigslist it
Old 03-15-2008, 11:09 AM
dochall22's Avatar
i just didnt know if they were stronger/better for some reason, didnt know why they are on a vette if it's not the best?!?
Old 03-15-2008, 11:19 AM
Oso SS's Avatar
IRS is good if you want to go around a lot of corners. If you're road racing or auto-xing the car it's something to look into.
But if you want any power to go through it or you want to go fast in a straight line, ditch it.
Old 03-15-2008, 11:36 AM
dochall22's Avatar
thanks! my car is a straight line car so i guess a 9r will be the answer
Old 03-15-2008, 11:41 AM
Awake455's Avatar
Not likely to see a net positive return on your time/money investment into an IRS for a straightliner.
A properly tuned 4th gen rear suspension is extremely capable at a road course or autox. It would come down to how much time and money you are willing to spend to be different. The lion's share of your efforts would be spent in getting it back to the level of a properly tweaked F-body solid axle setup.
The question becomes...do you want to go thru a great deal of fabrication, installation, and tuning of an IRS to achieve what can be done with the existing suspension? I'm pretty sure that, once someone successfully gets the thing installed and tuned, it could be made to outperform the solid axle torque arm panhard rod F body setup. The road between here and there is quite long and involved though.
Do another search on here, you will find an example of a member who has installed a (IIRC) C4 IRS.
Old 03-15-2008, 12:11 PM
dochall22's Avatar
awesome - thanks man! I dont have the time or patience to go that indepth - it was just an idea that crossed that i thought i would throw out there - thanks
Old 03-15-2008, 07:54 PM
keliente's Avatar
Here's the link to a shop that installed a C4 IRS.
https://ls1tech.com/forums/gears-axles/539526-4th-gen-irs-f-body-larger-pics.html
Old 03-16-2008, 07:42 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Ive seen a IRS in a fbody. If I were auto crossing it be something id consider.
Quick Reply: IRS from caddy on camaro?
