Fogs on with Highs mod?
I've read before when I had an Fbody how to clip a wire on the bottom side of the fog light relay and ground it, and the fogs would stay on when you switched to high beams.
Can I do this to my GTO? What color wire under the foglight relay to i clip and ground?
Looking at the schematic you just remove the Fog Lamp Cancel Relay(underhood) and install a jumper terminals 3&4 together. To find out witch one they are remove the relay and turn it upside down they are numbered.
When the relay is energized by turing your Hi beams on it opens a set of NC contacts on terminals 3 & 4 witch de-energizes power to your fog lamp relay.
****Beware: I have not tried this so don't blame me if you F something up.****
I have it done...pull the fog light cancel relay and simply bend the left most vertical pin out of the way or clip it off (hold the relay such that the two horizontal pins are at the top).
Works great, i have mine bent out of the way.
