Another p0748 code problem
Old 03-15-2008, 06:45 PM
Vinny1's Avatar
Default Another p0748 code problem
Hey guys. I did a search but eveyones Trans seems more moded than mine. I installed a Trans go in my car about 2-3 months ago (02 WS6) and about a week ago it threw a p0748 code. Its the pressure control solinoid. My car shifts fine except it shifts a little harder 1-2 than I like. Where is this solenoid and do I need to replace it or is there something else wrong?
Thanks
Vinny
Old 03-15-2008, 06:54 PM
LS1Tech Sponsor
performabuilt's Avatar
PO748 is (PRESURE CONTROL SOLENOID ELECTRICAL) I would check that the PCS is pluged in well the terminals have been known to break conection flat blade type and if all is good there replace the PCS.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-15-2008, 07:27 PM
Vinny1's Avatar
Where is it?
Old 03-15-2008, 07:50 PM
LS1Tech Sponsor
Its the large solenoid near the 1-2 acumulator in the pan , Its the largest solenoid in the trans so easy to spot just drop the pan
__________________
Call 888-744-6542
Old 03-16-2008, 06:19 PM
Vinny1's Avatar
Just out of curiosity. If I happened to not plug it up good enough or its bad would that cause the hard 1-2 shift at low speeds I'm experiencing?
If no I plan on reinstalling the original 1-2 accumulator springs while I have the pan off. Only one problem. I can't remember which springs they were! Or if I turned the piston upside down!
Thanks for the help
Vinny
Old 03-16-2008, 07:40 PM
LS1Tech Sponsor
If its a open circuit or unplugged yes it will cause very harsh low throttle shifts
__________________
Call 888-744-6542
Quick Reply: Another p0748 code problem
