SS brake lines
Old 03-15-2008, 07:48 PM
tavi_ws6's Avatar
Default SS brake lines
just making sure that these will work for a traction control car
http://www.ws6project.com/user_stor/...oducts_id=1749
thanks
Old 03-16-2008, 09:27 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Just reading that, it tells me that you would only use the 4 outer lines, thus leaving the two that go from the body to the axle as the stock, rubber on the outside lines.
If you just want to replace the stock lines at the wheels only, that would work. Otherwise, you'll need a new kit that has all 6 lines if you want to replace them all.
Old 04-11-2008, 10:52 PM
Beat98TJ's Avatar
A traction control car will have 6 hoses as stated above. Might want to look into a complete kit as are offered by other companies including Russell Performance.
