Little Confused, very irritated trans prob?
Ok I just had my trans rebuilt on feb 28 2008, i got it home and a day later blew my rear end, upgraded to a moser 12 bolt, well the shop that did the work took it for a test drive everthing was good until he was on his way back he was in first gear then when it was gonna shift into 2nd, it stopped the car. he got back to his shop, put it on the lift to show me, and put it in 1st, tires rolling then 2nd, tires stop, puts it in drive tires roll, when it shifts to 2nd tires stop, its like nailing the brake, they said the think it may be some "trash" in the valve body, i looked at my reciept of the rebuild and just says 4l60e rebuild on the invoice, any body have any ideas? The trands fluid was still red, and smely like new trans fluid, the trans isnt slipping. Thanks for any info in advance.
LS1Tech Sponsor
When the rear end failed it damaged the low roller clutch and locked it, Normally it holds in one direction and free wheels in the other , I have also seen this a few times with a rear end failure, While you will likley not have to rebuild the unit parts wise you will have to completely disassemble to do the repair(replace the low roller clutch) . Also I would carefully inspect everything else also , Planets etc. A failure like a rear end failure can put considerable stress on all the trans hard parts.
__________________
where could one go to pick up the low roller clutch and how much do they usually cost? the only thing I find odd is when he statrted out on the test drive it when thru all 4 gears but when he slowed down to pull a u turn is when itt happened,
