Newbie needs some NOS help
Hello was thinking about getting a NOS setup for my LS1 was wondering what shot would be safe (and by safe i mean no harm to the engine hehe) and do i want to do a dry or wet? what are the advantages and disadvantages of both?
Thanks
~Tom
Thanks
~Tom
Re: Newbie needs some NOS help
Dry Kit
Advantages:
1. Easy install
2. Breaks less parts (usually)
3. More Economical
4. Computer auto tunes for the spray.
Disadvantages:
1. Low rear wheel horsepower (125 shot=85 rwhp)
2. Catostrophic engine damage if injector fails.
3. Same as above if the fuel pump fails.
Wet Kit:
Advantages:
1. Very aggressive power hit
2. TNT and NX rate thier kits at the rear wheels.
3. Basically kicks a similar modded car with a dry kits ***
every race.
4. Tuning the car is a must (timing tuner or ls1 edit)
Disadvantages:
1. Breaks clutches and rearends more readily
2. Catastrophic engine failure if fuel selinoid malfunctions.
Hope that helps. To be honest I would recommend the wet kit. I had a dry kit for my first system and grew bored of it very quickly. When I changed over to the TNT F1 system, and hit the juice for the first time, it literally scared the bejebus out of me. And it fried my clutch a few seconds later. But going fast is never cheap.
Hope this helps, good luck.
Advantages:
1. Easy install
3. More Economical
Disadvantages:
Wet Kit:
Advantages:
every race.
Disadvantages:
what do you think about a 2 stage nitrious kit with a low shot? wouldnt that be a little better in terms of not wearing parts out as fast?
Its Nitrous, not NOS. N.O.S is a brand. With no disrespect intended. Instead of a two stage get a progressive controler, this will allow the N20 to be released slower so its easier for the drivetrain. This is good because you have a 6 speed. The rear ends are the weakest link and break often.
