02 LS6 springs in an 01 FBody?
I'm thinking about installing one of these 2 Comp Cams:
216 / 220 .525 / .532 114 LSA
212 / 218 .522 / .529 114 LSA
Would the '02 LS6 springs work okay with these cams? Also, do the spring seats need to be changed with the '02 LS6 springs? When I did a search, someone mentioned that you need the '02 seats to get the installed height correct. The rev limiter is going to stay stock, at least for now. I really won't get much by raising it with these cams anyway The reason I'm thinking about going with the LS6 springs is to keep the valvetrain noise down.
Thanks!
Thanks!
