Spec clutch shim install
Old 03-16-2008, 10:17 PM
bigtim02ta's Avatar
Default Spec clutch shim install
ok i removed slave cylinder to install my spec shim there is a black plate with two bolt holes in it does it stay and put the shim behind it or take it out.
Old 03-16-2008, 10:30 PM
DAVESS02's Avatar
It sounds like you have a shim already. How thick is it? Do you have calipers to measure it in thousandths? A Ram shim is steel and .150 thick. How thick is the spec shim BTW?
Old 03-17-2008, 02:35 PM
bigtim02ta's Avatar
yeah it had a steel one in it and a ram clutch and is maybe 1/16th to a 1/8th inch thick the clutch isnt here yet just getting everything ready
Quick Reply: Spec clutch shim install
