TEX OZ700 X Grip is parts for sale
Next, is a Textralia 0700 (X-Grip) clutch w/ billet flywheel. This clutch has right at 500-600 miles on it. After it was broken in, it was taken to the track 1 time. Unfortunately, it was mated to a 440cid LS7 with spray. So it slipped on the very first pass. It was immediatly pulled after that.
With the exception of a couple hot spots on the flywheel and PP. (like almost all clutches) it it PERFECT. The pad thickness is probably 99%. There are no grooves in in the flywheel. All in all, I would say its almost new.
It REALLY pisses me off that I need to sell this clutch, cause its perfect for a 500-650rwhp car. I need a Z-grip. Basically, the X-grip is the more streetable version of the Z-grip. This clutch can be used from anything from stock to 600-650rwhp (and tracked) Anything over that, it would start to question it. The pedal pressure is as close to stock as you can get.
You can be my guest to verify with textralia my claims
Huh, that's weird that it was broken in for 500-600 miles considering one of the big features of the clutch is that it requires no break-in period. I can see maybe a hundred miles or so just to make sure everything was installed properly and there are no problems, but perhaps someone didn't do their research.
Good luck with the sale!
