Lt1 swap in a 94 3.4 5 speed
That wouldn't work. If they even could find a bellhousing to mate it up, I'm sure it wouldn't last long. He'll need a new K-Member for a V8, and I wouldn't doubt a new trans cross member for either the M6 or A4, depending on what he ends up using.
Mechanically:
-Engine/transmission/driveshaft(as most pre-97's have 2 piece driveshafts)
-if swapping from T5 to T56 you'll need a lower shift boot. (~$35 at GM)
-most accessories/bracketry
-engine k-member
-I had drum brakes so I swapped to LS1's all around
-fuel pump
-exhaust components
Electronically:
-engine harness
-I used the 95 engine bay harness and have adapted it to connect to the interior harness and engine harness through the factory plug ins
-PCM
-most will say you need to swap steering colums due to vats but if you get a basic tune before start up you can just tune out vats.
That's the basic jist of things. If you have any specific questions feel free to PM me. It's been a long process and this is just what I can come up with in 5 minutes of sitting here.
I would also suggest replacing anything that you don't want to have to go in and replace later on. ie: motor mounts, oil sending unit, if you're doing headers etc...anything that will be easier to do now while it's out then later when you'll have to struggle. haha.
Personally I would just buy an LT1 car. That being said, I can definitely appreciate the work that goes into any project that big! tbird31, you're car came out awesome! Very nice work!
1BADAIR, good luck with your friend's project!
I work for a performance shop in Charlotte, NC. Zeus Performance.
Mechanically:
-engine k-member
-fuel pump
-exhaust components
Electronically:
-engine harness
-PCM
Mechanically:
-engine k-member
-fuel pump
-exhaust components
Electronically:
-engine harness
-PCM
