Removing oil pan, motor in car, PA K member?
Re: Removing oil pan, motor in car, PA K member?
its very do able... i have a BMR K member and I pulled the oil pan... i used a jack on the trany to keep the motor supported... take the Motor Mount bolts out... u dont even have to lower the whole K member off... just let the six bolts lose to a couple of threads, which will be ok because they are only supporting the K member... didnt have to unbolt the shocks from the a arms or anything ... just the 2 Motor Mount Bolts come out... and the 6 K member bolts get loosen
