How much play when your headlights are closed?
Hey guys,
when your 4th gen's headlights are closed, if you tug up on them gently, how much play is there? what's acceptable?
one of mine has more than the other, and i can;t seem to eliminate it. the greater amount of play is maybe 1/4-1/2 inch up.
thanks!
thanks!
it my experience the play varies on the condition of the motor
I dont think there is any specific tolerence for them and if there is maybe a collision shop would know
And stop tugging your headlights, you'll go blind : P
My one car has a weak motor on one side and you can lift the closed light up about an inch farther than the good side
do you ever notice that when closed the headlight flaps in the breeze? i don;t beleive that mine do.. but i really can't confirm.
interesting. well when i pull up on the headlight, i see the linkage moving, and not the motor.. but your point is good and i'll investigate.
upon a close inspection last night, the elbow analogy is valid. i'm not sure if it's a result of a damaged motor, but there is "wobble" in the elbow. i beefed up that little tab-bumpstop and that seems to have helped dramatically.
