Stock Cam Advertised Duration?
Apologies if this is easily found somewhere--I've searched for several hours. I would like to know the stock cam specs for a 2002 LS1, including advertised duration.
Re: Stock Cam Advertised Duration?
<a href="https://ls1tech.com/threads/showflat.php?Cat=&Board=UBB1&Number=591148 &Forum=UBB1&Words=what%20are%20"stock%20ca m"%20specs&Match=Entire%20Phrase&Searchpag e=0&Limit=99&Old=allposts&Main=590970& amp;Search=true#Post591148" target="_blank">https://ls1tech.com/threads/showflat...=what%20are%20"stock%20cam"%20specs&Match=Entire%20Phrase&am p;Searchpage=0&Limit=99&Old=allposts&M ain=590970&Search=true#Post591148</a>
Thanks for that, but that only shows .050" lift figures. I'm looking for the advertised duration to use in Intake-Valve-Close (IVC) event timing calculations.
Add 50 degrees to those figures and you will know pretty close what advertized duration is. A better question is why do you care? The stock 2002 LS1 cam for an Fbody is a truck cam! If you have a Tahoe it has the same cam in it, nothing special here.
Calculating the dynamic compression of a stock 2002 LS1 might be a worthy exercise, it might not. To complete the calculation requires precisely knowing Intake Valve Close, measured from the advertised duration.
