Locker Lube?
Old 03-17-2008, 11:57 PM
chuckyt1's Avatar
Default Locker Lube?
What's everyone using for gear oil in their 9 inch Detroit locker?
Old 03-18-2008, 02:05 AM
ae13291's Avatar
which locker? are you talking about the factory zexel?
Old 03-18-2008, 10:20 AM
Jays00ss's Avatar
Regular Valvoline 75-90 weight. Like recomended. You are not supposed to use synthetic or any additive (Its is not a LSD therefore you do not need it) In fact if you do use synthetic, it will void the warrenty.
You can go to a heavier weight (some say it quiets the locker mechanism down) but I kinda like the clunking LOL.
Old 03-18-2008, 10:44 AM
alamantia's Avatar
Since when does the use of synthetic oil void the warrenty of a locker?
Old 03-18-2008, 11:00 AM
Jays00ss's Avatar
https://ls1tech.com/forums/gears-axles/883571-synthetic-oil-note.html
Look at the Eaton's install instuctions on the Detroit Locker. They Specifically tell you NOT to use Synthetic oil.
Old 03-18-2008, 11:04 AM
alamantia's Avatar
Thats just a post on a forum. Heres the owners manual for an Eaton Detroit Locker, you tell me where it says the warrenty will be void of you use synthetic.
http://www.eaton.com/ecm/groups/publ.../ct_128312.pdf
Old 03-18-2008, 11:19 AM
Jays00ss's Avatar
You are Right I just called Eaton, They recomend not useing Synthetic but if you do, it will not Void the Warrenty on the Detroit locker.
Old 03-18-2008, 11:27 AM
alamantia's Avatar
I have had two lockers in the past and I can not ever remember there being any stipulation in the owners manual. I could understand in an Eaton LSD where theres friction involved between the clutch packs, but for a locker... idunno, i couldnt see it being an issue.
