Lets play whats this noise
Old 03-18-2008, 12:57 AM
Jsonchevz's Avatar
Default Lets play whats this noise
My 99 Z28 A4 has a very loud growling noise from the rear end but only when I turn to the right and am off the gas or the brakes this noise is driving me crazy I have replaced everything including seals bearings posi and gears the only thing I haven't replaced is the axles. Some one tol me that the heat treating can wear off the axle and make this noise but it won't hurt anything. One other thing I have been driving it like this for two years and when I change the gear oil I don't get any metal shavings other than the usual I've also had it at the trackseveral times with no problems. The posi is an auburn but I had this noise with the torsen also THANKS
Old 03-18-2008, 06:01 AM
alamantia's Avatar
Are the axles scored, pitted or damaged where they ride on the axle bearing? Try axle saver bearings.
Old 03-18-2008, 10:21 AM
Jsonchevz's Avatar
how would I know if the axles are scored
Old 03-18-2008, 10:31 AM
alamantia's Avatar
look at them
Old 03-18-2008, 10:42 AM
alamantia's Avatar
http://www.champcarfanatics.com/phot...ze=big&si=axle
Old 03-18-2008, 11:33 AM
Jsonchevz's Avatar
i will check them out as soon as it stops raining here in ohio
