Is a 4" intake pipe overkill
Old 03-18-2008, 02:13 AM
Banshee Ben's Avatar
Default Is a 4" intake pipe overkill
What do you think the efficiency if from a 3" to a 4".
I know the tb is closer to 3" but the easier it can take it...
I have twins running into two 2.5" inlets on the inter cooler then a outlet of undetermined size. Then straight to the TB.
Old 03-18-2008, 07:22 AM
smokinHawk's Avatar
my TB is 4" od which hooks up nicely to a 4" tube.
overkill, maybe if your trying to only make 500rwhp, but if your shooting for 1k rwhp, it might help some
my turbo has a 3" outlet, here i run that size tubing to my IC, where i made it have a 4" outlet, then that size tubing to the TB (no maf).
Old 03-18-2008, 07:51 AM
Z06PSI's Avatar
Well 78mm roughly = 3"
90mm roughly =3.5"
100mm roughly = 3.9"
Choose accordingly.
Old 03-18-2008, 10:16 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ How about LT1 throttle bodies? I don't have one here to measure.
Old 03-18-2008, 10:30 PM
Z06PSI's Avatar
52mm is 2.0 inches
58 2.28 inches
Old 03-18-2008, 10:31 PM
Sideways240sx's Avatar
i agree with the tb thing, but your intake is feeding your turbos. Then it is pushing past the tb. I would think what ever size the inlet is on the turbo is should be good, because you are not restricting the turbo. My inlet on my turbo is 5 inches, but i just put a 5 inch arifilter on it and called it a day.
Chris
Quick Reply: Is a 4" intake pipe overkill
