Car won't hook
Old 03-18-2008, 03:30 AM
kratos2250's Avatar
Default Car won't hook
I have a 2002 camaro with about 400 horse, and can't get the thing to hook. What suspension mods do I do to help this out?
Old 03-18-2008, 03:32 AM
jessedale98's Avatar
kind of a weak question. List what you have!
But for starters you will need TIRES,LCA'S,TQ ARM,SFC'S,QA1 ADJ'S
Old 03-18-2008, 03:40 AM
kratos2250's Avatar
sorry I have a touquer v2 cam 3200 rpm stall with a set of mt's and I was at the track last weekend and it kept spinning off the line could'nt get it to hook for nothing
Old 03-18-2008, 04:43 AM
junior28570's Avatar
Was anyone else having issues launching? I pay attention to what others are able to do before I start questioning my set-up.
I'd recommend LCA relocation brackets and use the lower hole. Made the most improvement to my 60' to date. All those things jesse listed will help even more.
Old 03-18-2008, 07:45 AM
BORN2LOSE's Avatar
Yep, LCA relocation brackets especially when the car is lowered.
Old 03-18-2008, 07:50 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Is it currently all stock suspension parts? or do you already have a few components replaced?
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 03-18-2008, 01:03 PM
1Loudz28's Avatar
Lower control arms, relocation brackets, torque arm
Old 03-18-2008, 05:50 PM
kratos2250's Avatar
completey stock suspension and yes pretty much everybody else was launching
Old 03-18-2008, 06:06 PM
COOKIE MONSTER's Avatar
Whats up dirtbag! he he
Old 03-18-2008, 06:11 PM
Ok, heres what I suggest. Go to TSP or Maryland speed, order yourself some Spohn Adjustable Lower Control Arms, pick any color you want because spohn doesn't ***-rape you like BMR does when it comes to price difference over a damn color. lol Then get a set of LCA relocation brackets. Put them on the bottom hole. Also what MTs are you using? What gears?
Old 03-18-2008, 08:57 PM
linegtdt52's Avatar
Default Hold Up!!!
Here is what you do :
Call Dennis @ BMR and pick up
Bolt in relocation brackets for rear lower control arms
New tubular lower control arms non adjustable
TA001 Adj. torque arm
a set of QA1 on back to begin with
Old 03-19-2008, 03:43 AM
M-Ten's Avatar
whoa whoa.. what about some good tires? suprised nobody said that.. throw some 315 nittos on there... I did and have no problem hooking up.. I only launch from about 1700 now though, cuz i get some slight wheel hop, but when i still have stock suspension.. so when i upgrade that it will be about perfect...
Old 03-19-2008, 03:45 AM
M-Ten's Avatar
oh sorry guess you did say tires... but yeah that's the first thing you should do, no question about it
Old 03-19-2008, 08:51 AM
I also asked what tires. Dont get non -adjustable LCAs, they're a waste of money if you're gonna continue modding your car. Also, for 400hp, you dont need damn QA1s in the rear to hook. ****! I asked oyu what gears you got? if you have 4.10s I would suggest getting a set of Mt 135/13/17 ET Streets, or a 27 slick/cheater. Anything less you could use a set Nitto 555rs for. But first, get LCAs (Adjustable) and relocation brackets.
Old 03-19-2008, 05:58 PM
if you have 4.10s I would suggest getting a set of Mt 135/13/17 ET Streets.
WHAT? .. Come on now .. the man aint drivin' a mountain bike at the track!
Old 03-19-2008, 10:26 PM
sidewayz28's Avatar
my non adj LCAs are fine..
id say since you have tires you need an adj. torque arm, LCAs, relocation brackets and adj panhard bar
Old 03-19-2008, 10:47 PM
transamws6_97's Avatar
tires will make the biggest difference. if you are running a 10-bolt i would suggest just staying with drag radials. When it comes to actual suspension pieces from my experiences a chassis mounted torque arm made the biggest difference. It really pushed my tires into the pavement for great traction increase. The second most improvement was lca relocation brackets. and lastly subframe connectors really tied it all together and if you get a bmr torque arm you need sfc to weld the crossmember to. I had lca installed and they did absolutely nothing to increase traction. If you really think about the forces lca take the stock pieces are plenty.
Old 03-20-2008, 07:05 PM
DGraboyes
Guest
Posts: n/a
what helps eliminate wheel hop?
Old 03-20-2008, 07:47 PM
2manycars's Avatar
FREE MOD!
More PSI in tires = More pounds in tire = Heavier tire that won't hop as much!
Old 03-20-2008, 08:34 PM
M-Ten's Avatar
i hardly hop anymore since I put new tires on.. that's the first thing IMO you should do to improve traction/wheel hop.. then worry about the suspension, that's what i'm doing.
I get a small hop on launch, and sometimes a small hop going into second
Quick Reply: Car won't hook
