need to know if anyone can tell me approximate idle
does anyone know about how the idle quality of a cam with specs 220int 228exh int 0.614 exh 0.597 on a 114 LSA
Re: need to know if anyone can tell me approximate idle
Well, from all the research I have been doing on cams...I would say that cam will idle pretty good, but that is definitely alot of lift for such a small duration.
But, I am guessing it will make power from 2300-5900 (give or take about 300rpm)...
Thanks man I also have a set of heads that are at about 1.5 port stage. I hope to put about 370 to 380 rwhp in an A4.
