Tuning an auto car with Edit
LS1TECH Sponsor
Re: Tuning an auto car with Edit
If I were you I would find where you make peak power and determine how fast the car drops off after you have passed the peak. if it is within 10 hp then I would set the 1-2 300 rpm past the peak power the 2-3 200rpm past and the 3-4 150 past. The way to do this is to increase the MPH in the shift tab and then make them all the same. ie if the mph was 1-2 33mph @6000rpm 2-3 65mph @6000rpm make them 1-2 36@6300 2-3 68mph @ 6200 all this is assuming you are making peak @ 6K but you are probably higher about 6400 but you get the point. The shift tab is only enabling a shift it will take an instant for it to occur though. The MPH and RPM have to be met before this will occur. 0 out the upshift tq red, inc line press 125% accross and then I would set the shift time to .2 sec any shorter and you could be burning clutch packs. Hope this helps If you have any questions please feel free to give me a call 813.253.0961
Jeremy Formato
Jeremy Formato
