bigger crank pulley??
were can i get one for a 6 rib set up ?? i was told that if i get a bigger crank pulley then i could make more boost out of the P1SC, so do any of you know were i can get one at?
FWIW, I have an 8" MMS 6-rib, and I still get pretty mad belt slip @ about 5k RPM and up. IMO just get the 8 rib. I don't see why the 8" APS pulley would be any different from the 8" MMS, probably still slip.
And no, it wont hurt your blower unless you pulley it up too much and exceed the max rpm of your P1.
