Well time for new rottors & brakes
Old 03-19-2008, 11:45 AM
SIC LSX's Avatar
Default Well time for new rottors & brakes
Whats the best bang for your buck that r the cheepest?? I want slotted & drilled rottors and some pads that dont put out that much brake dust. Thanks!!
Old 03-19-2008, 01:15 PM
9000th01ss's Avatar
I use Hawks HPS pads, they are low dust when they get broken in.
As far as rotors, get the cheapest you can find.
A supervisor at Centric parts told me all brake rotors come from china as blanks, then most companies do thier own mods to them like cryo treating, drilling, slotting, etc.
There is one Aimco number for 100's of different brands and styles of the same f body front rotor.
This obviously doesn't apply to high end racing rotors.
I'd get a cheap plain or slotted rotor.
I have WS6 Store house brand slotted C5 up front and PBT slotted in the back. They have the silver coating so the hat part stays rust free.
Old 03-19-2008, 01:24 PM
LS1TECH Sponsor
Sam Strano's Avatar
That's simply not true.
A lot of rotors are Chinese, expecially the cheap ones. ATE's aren't, Brembo's aren't. We have "cheap" rotors too, and they act like it. I tried a few sets of them. The weight varied greatly, as much as 3 pound less than quality replacement, and in rotors mass = the ability to absorb and expel heat. The inability to do so is one factor in warping.
We pretty much only recommend and sell Brembo's or ATE PremiumOne rotors. And we almost exclusively use Hawk pads.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 03-19-2008, 02:43 PM
Undertow74's Avatar
Yea +1 for hawk pads.
I got my whole set of pads and rotors from a sponsor on here BSI brakes. damn good deal if you ask me, and they work well too.....
Old 03-19-2008, 02:46 PM
ls1leadfoot's Avatar
i used a place called i rotors a few years ago.....still have the same pads and rotors on the front....
and stock on the rear!!!!!!!90k
Old 03-19-2008, 03:02 PM
CCCustoms's Avatar
go for Bear EradiSpeed+ Rotors (They are drilled and slotted, the front ones are two piece and the rears are one piece they are 65 1bs. lighter than the stock discs).
and the best pads are Carbotech Performance Brake Pads, They produce 0 dust, but they do squeak when they are cold.
Old 03-19-2008, 03:18 PM
9000th01ss's Avatar
Which part? I'm only relaying what I was told.
The guy I talked to was in the chinese rotor bussiness.
I'm sure any additional info you could provide would be appreciated.
How can you tell by looking at a rotor if it's of good quality, and where it was made?
Like I said, my rotors came from two different suppliers and they look almost identical.
I didn't see the point of so much of that silver plating on the brake surface though, I think that caused my pads to not bed in properly because it was there for at least 50 miles or so.
Old 03-19-2008, 03:21 PM
LS1TECH Sponsor
Sam Strano's Avatar
The part about all blank rotors come from China. That's not true. As for telling the quality of a rotor by just looking, you can't really do that any more than you can tell the quality of a brake pad just by looking at it.
__________________
Old 03-19-2008, 03:53 PM
9000th01ss's Avatar
I know they're not all made in china, just the bang for your buck kind that the op might be looking for and most any parts store stuff. They might be alright for normal driving.
Old 03-19-2008, 04:01 PM
LS1TECH Sponsor
Sam Strano's Avatar
But you repeated the claim that they were..... And many are under the assumption that the rotors make the car stop faster. They do not. You buy quality materials that are more warp resistant, that can absorb more heat, that don't wear as quickly. Yes, a cheap white box rotor will stop the car fine. They don't generally weat as well or tolerate abuse as well.
Rotor are made of iron, there are different grades of iron. Rotors can have varying amounts of metal in them. I've seen F-body rotors with half as many vanes (and that much surface area for cooling) as others.
__________________
Old 03-19-2008, 04:06 PM
presto_z's Avatar
i got summit brand drilled and slotted rotors with hawk pads, and they were a huge improvement over the stock brakes and they look kick ***. but then again my rotors were warped when i bought the car, so anything would be better then that.
Old 03-19-2008, 04:24 PM
00SSog's Avatar
http://thunderracing.com/catalog/?ac...vid=3&pcid=226
check out the brake pack. at the bottom of the page
Old 03-19-2008, 05:43 PM
LS1TECH Sponsor
Sam Strano's Avatar
Or.... you can check out my brake products: http://www.stranoparts.com/searchbym...D=17&ModelID=7
__________________
Old 03-19-2008, 09:57 PM
jmilz28's Avatar
Just silly not to go with Sam.
Old 03-19-2008, 10:54 PM
SIC LSX's Avatar
edit 1st post
Old 03-20-2008, 01:22 AM
35th SS's Avatar
look into some brembo blanks and hawk ceramic pads and be done with it.
Old 03-20-2008, 07:38 AM
Hatchetman337's Avatar
I bought Summit brand drilled/slotted with EBC greenstuff pads and I've very happy with them. After almost a full summer of use, no warping or anything yet.
Old 03-20-2008, 11:52 AM
kny3twalker's Avatar
I personally just bought brembo rotors and hawp hps pads, but I bought them from rotorsonline.com, rotorsonline.com can zinc plate them to prevent rust as well as cryogenically treat them. I have found no other supplier which offered these treatments
Good Luck
Old 03-20-2008, 12:02 PM
SS101's Avatar
i'd listen to sam over pretty much anyone else about this kind of stuff...i've needed some new brakes for a while now but i don't think i'll have the money on hand to do them for a few more months lol. btw, i'm loving the prices on the brembos sam, much lower then other places i've seen.
Old 03-20-2008, 01:25 PM
z28bryan's Avatar
Not to be a wise guy, but I love these brake threads. It's like everyone picks a random pad and rotor and recommends it.
I would say the best bang for your buck are brembo blanks. For ~60 dollars a rotor you get a trackable rotor. I consider the cheapest to be like the autozone rotors, and your paying 20 bucks more which isn't bad in my opinion.
