Coolant
Coolant
I am putting in a 160 thermostat.I am reading the directions and it says to unscrew the pressure side bleed screw so it doesnt splash on the distributer.The coolant level will drop when screw is open all the way. So will all the coolant in the radiator be lost then?
I pick up the dex-cool 50-50 blend for my car is that right?
Do i need to use anything gasket sealer on the thermosat housing to make it seal?
I am asking because I dont want to do it wrong at all. thanks
http://www.installuniversity.com/ins...sity/index.htm
all the info youll need for the swap!!
*edit* just saw what you wrote about the distributor...the write up above is for ls1s.
its an LT1...also my friend had a hypertech programmer..its the same year camaro as mine..so there shouldnt be any reason for it not to work right..
