how to tell what gears you have
I have 3 rear ends that are not on cars how can I tell what gears are in it. I tryed to spin the yoke and count how many times the rotor goes around but that doesnt seem right. So how do you tell. thanks.
Also how do you tell if its a posi.
Count the teeth on each gear. Divide the number on the ring gear by the number on the pinion. Or, you could do what you started to do. Spin the hub and count how many times the pinion spins. If it spins about 3.4 turns, it's a 3.42, etc., etc.
