Strength of 3.90 gear vs others?
Old 03-19-2008, 07:47 PM
JoeliusZ28's Avatar
Default Strength of 3.90 gear vs others?
Does anyone know how it compares? I havent been able to find any tooth counts or anything like that. Thinking about a 3.90 swap soon.
Old 03-19-2008, 07:49 PM
StealthFormula's Avatar
Well the more teeth on the ring gear I believe the less strength. There is more teeth on a 4.10 ring gear which would make it less strong than a 3.73 or 3.42 gear that has less teeth. So a 3.90 gear would be a tad stronger than a 4.10 would but a tad less strong than a 3.73.
Old 03-19-2008, 07:51 PM
JoeliusZ28's Avatar
yea i know but it also depends on the ammount of teeth the pinion gear has. For example a 4.11 is stronger than a 4.10.
Old 03-19-2008, 08:03 PM
If your talking about a 3.90 gear for a 7.5" 10 bolt I believe the only manufacturer that makes 3.90's for our rears is Motive so I would give them a shout and they could tell you how many teeth are on the pinion gear.
Old 03-19-2008, 08:48 PM
Pro_built7's Avatar
is there a reason you're not going 4.10 man?
Old 03-19-2008, 10:34 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Actually the strength is due to the pinion size, it has nothing to do with the ring gear. A 4.10 has less teeth on the pinion than a 3.73 & it is also smaller in diameter, making less available tooth contact & therefore less ultimate strength. This makes the higher numerical gears weaker.
Old 03-20-2008, 02:11 AM
JoeliusZ28's Avatar
yes, I want some RPMs to spare when finishing the 1/4.
so can anyone tell me how many teeth are on the pinion?
Old 03-20-2008, 02:15 AM
Revelation Z28's Avatar
10 pinion, 39 ring gear.
Old 03-20-2008, 03:59 PM
JoeliusZ28's Avatar
hmm, so a 37/9 4.11 would be stronger then by the sounds of that...
can anyone give me the counts on 3.73 or 3.42?
I dont want to do this if its gonna be considerably weaker.
Old 03-20-2008, 04:20 PM
LT1Falcon's Avatar
i cant imagine its gonna make or break ya, the 10 bolts either gonna hold up or its not. its not like your comparing 2.73 to 4.10. 3.73 to 3.90 cant make that big a difference as far as strength i wouldnt think.
Old 03-21-2008, 11:21 PM
JoeliusZ28's Avatar
yea i just plan on running DRs for just enough passes to get me a 12 (then im taking em back off). My car can be pretty mean on the shifts too, i chirp 4th pretty consistently.
Old 03-21-2008, 11:23 PM
thank your clutch for the 4th gear chirp lol it must grab like welding a pipe on shifts.
Old 03-22-2008, 01:51 AM
Formula350's Avatar
Don't the shafts usually go on 10bolts before the ring/pinion?
Old 03-22-2008, 02:04 AM
what shaft? pinion shaft/axle ? lol
Old 03-22-2008, 07:32 AM
Formula350's Avatar
The only shafts I consider to be in the rear is the axles.
Old 03-22-2008, 04:31 PM
^ lol re-read that sentence up to "is"
our axles should hold up before the gear teeth, worn out axle bearings are what usually take them out sooner than the gears.
Quick Reply: Strength of 3.90 gear vs others?
