NX on stock engine how much,,,?
am thinking to spray 100 to 150 shot wet kit
on a stock ta A4 with ( hookersLTs,ORY,flow, NGKtr6 gap36)
so iis it ok to spary the 150
Re: NX on stock engine how much,,,?
hell ya...I spray 175 on my car most of the time,but toolin around 125-150.I have a a4 and on 125 my car went 11.50@118 bone stock on 255/50/16 bfg dr's....on 150 it's went 11.20@125.4
want some advise to hook...remove the front sway bar and get some et streets..my car cuts 1.52-1.60's all day with no converter spraying out of the hole....oh and your car is way more modded than mine so it should run real good.
So far I am only spraying a 75 shot on mine. However, it's an LT1, not LS1. I am playing it safe. Would rather lose a race than lose the motor. I am sure I could put a little bigger shot on it (100 or 125), but am just experimenting with it for now.
There is a guy I know here in town that routinely sprays a 100 shot on his basically stock LS1 and he has no problems.
Restricted User
SilverTA, depends on yr of car. I wouldnt push too much, a 100wet sure. But with your mods, you might start starving for fuel on the top..especially if ya got a 99-00. Little injectors and stock pump on a modded car, may not be too cool at 150!
I would play it safe and stick w/ a 100, unless you get the 125 jet, but still....you can only push so much.
Why not just put in the fuel pressure safety switch to make sure you don't starve it too much. A buddy of mine did it on his stock motor with a 150 shot and stock fuel system with no problems at all.
i did it today with 150shot what am ganna say wowowowowowow,,
thanx guys for the help
next week H/C will be in , a pigger fuel pump,tunning
hell ya...I spray 175 on my car most of the time,but toolin around 125-150.I have a a4 and on 125 my car went <a href="mailto:11.50@118">11.50@118</a> bone stock on 255/50/16 bfg dr's....on 150 it's went <a href="mailto:11.20@125.4">11.50@118">11.50@118</a> bone stock on 255/50/16 bfg dr's....on 150 it's went <a href="mailto:11.20@125.4</a>
