Southern Members - Anyone want to make a few dollars...
joshua022
03-20-2008, 05:15 PM
setting up the rear end in my truck?? Someone who has done a good bit of rear end work would be nice.
I just swapped in a detroit truetrac and some 4.10s and.....I have done a few rear ends but I guess I got lucky setting them up. Because this one is whining on accell, cruising, and decel.
I'm just going to deal with it until after next week and then buy some more gears and install kit if someone can help.
I have a shop w/lift I can use in Atlanta, off of S. Atlanta rd.
And I'll do everything if you'll just set up the gear depth, backlash, all that stuff.
let me know if anyone might be interested.
-Joshua
Superado
03-20-2008, 11:01 PM
I can hook you up with a guy that can do it...let me know if you need his number...
joshua022
03-21-2008, 09:26 AM
I'll talk to you about it at the g2g on the 30th. thanks
Superado
03-21-2008, 09:30 AM
you're not gonna install it before then?
joshua022
03-24-2008, 06:21 AM
-Joshua
Its in there, but its making noise!
joshua022
03-24-2008, 06:22 AM
I may not run it anyways at the g2g if my freekin tranny and converter don't get here in time to install.
Cuz my stock trannys slipping some so I've been babying it for a while.
