**TTP Camshaft Installed Package Deals - Get Equalized & Punished!
Time for another Cam Only Special to kick us off into Spring time!!!
- TTP Equalizer V.2, V.3, or Punisher V.4 Camshaft OR ANY Comp Cam Grind
- Patriot Gold Dual Spring Kit
- Trick Flow Hardened C/M Pushrods
- GM OEM Gasket/Bolt Installation Kit
- LS2 Timing Chain
- Full Professional Installation
- Full Custom Dyno Tune Including WOT and Part Throttle Tuning
FBody $1750
GTO $1800 (-$75 if LS2 Timing Chain equipped 05-06)
C5 or C6 $1900 (-$75 if LS2 Timing Chain equipped 05-06, Add $50 for LS7 timing sprocket for 07-08 Single Bolt Cams)
You can check out some of the graphs at www.ttperformance.net/Gallery/
We have Equalizer V.3's in stock right now and receiving another order of cams shortly from Comp!
- LS2 Timing Chain
FBody $1750
LOL. They are nice. Brad I should have pics for you soon. It's like pulling teeth getting 4130 rod ends right now. I finally pieced together a set of 6. I was about to get you clevis tabs, hehehehe
