::::::::::::::::ford 9" and 12 bolt for a 96t/a help info
ok i have no idea about rearends and want to no more. im going to put a cam in my 96t/a and i already have installed a 150 shot.Im afraid im going to blow the rearend.so i was told to get a ford9" or 12bolt.how pricey is it to do all this and how hard is it to install everything to fit right.
thanks
thanks
Direct bolt-in's are in the ballpark of 2500 for a 12bolt GM or a Dana 60. But you can find some used cheaper if you shop around on the Ebay or what ever. I am not a real big fan of the 9in but its a 100000 times stronger than the 7.5 10 bolts in our cars ,but dana 60's are very tuff and you dont have a ford part in your car. check out Strange
i got a ford 9" lined up and a 12bolt.how much would it cost me to convert this to fit into my car and get it working perfect "getting stuff to line up brakes/coil exc.
thanks
thanks
That's MISTER MODERATOR
If your car has the three channel ABS (plug on the center of the rearend) you'll need the 12 bolt.
The 12 bolt is lighter in weight than the 9 inch and has about 3% less loss due to it's gear angle configuration. It's way lighter than the Dana.
Unless you're making more than like 600 RWHP, you'll never need anything stronger than the 12 bolt. And it's a GM design. Go Strange, I've heard many bad stories about Moser about fitment, noise and availability.
I have a bud with a blown 800 HP '66 Impala with a 12 bolt. He hooks. He's broken everything except the rear. It doesn't even make any noise.
LS1TECH Sponsor
thanks
thanks
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
