4l80e converter not holding 1000rwhp /need help
Old 03-21-2008, 06:49 AM
hawkls7's Avatar
Default 4l80e converter not holding 1000rwhp /need help
I have a gto warhawk403ci et ls7 heads first dyno pull made 940 rwhp . at top end we had belt slip , so we have upgraded drive system to gilmer . we have stoped the belt slip and gained 3 pounds of boost at intake. Now the converter is not able to hold the power on the dyno . what brand of converters are available at my power levels , the car is street with 19 inch rims 275 rears. The trans is a 4l80e engine makes most power from 4000-6500 rpm. stall should be in range from 3200-4000 any sugestions.
Old 03-21-2008, 08:24 AM
Circle-D's Avatar
I am working on a new 5 Disk lock up for the 4L80E. It will be a month or so before they are ready. It is designed to hold 1000 HP lock up. Give me a call if you need more info, 713-895-8834.
Chris
Old 03-21-2008, 08:44 AM
cablebandit's Avatar
call Mike at Yank. Mightymouse has their converter in his daily driver 1000rwhp 4l80e firbird...3700+ pounds and its holding....3200ish stall. I have their converter also in my turbod 4130# firebird with an 80e but havent put any *** to it yet but so far so good.
Old 03-21-2008, 10:06 AM
Websy21's Avatar
+2 on the yank 3200 but I ended up knowing someone and went custom but if I did it again it would be the yank hands down!
Old 03-21-2008, 11:25 AM
LS1curious's Avatar
You will probably want a 10 inch converter or 10.5. if your thinking about 9.5 inch converters with that much power they can barely hold on at 600hp. Of course this depends on the dyno to so you never know. If its making a true 1000rwhp that thing better run bottom 8's.
Old 03-21-2008, 08:26 PM
TwnTrboCE's Avatar
Midwest Racing Converter here along with the quickest and fastest 4L80E in the world.
Old 03-22-2008, 05:25 AM
hawkls7's Avatar
Thanks for responce , what stall speed are you runing on the street or are both cars street and strip also what moods have been done to converters. I built my 4l80e with a friend who owns a trans shop parts were the best money could buy from US . so far the trans hasnt faulted fingers crossed. The converter we have is heating up and is not coping well on dyno.
Old 03-22-2008, 03:09 PM
Mike101's Avatar
is anyone running a neal chance converter for an 80 with boost? how are the neal chances on the streets? I am going to soon be in your boat but I am either gonna go with yank or maybe neal chance if I can get some feedback with them
Old 03-22-2008, 04:27 PM
Yank's Avatar
Call us we have been building and designing converters for the 4L80-e from its prototype state (1989) with the Gm Motorsports Off road teams and have the converter you will need!!!
775 826 9955 Dave or Mike
Old 03-22-2008, 06:20 PM
mine is only about 2400 stall it seems but i will let you know next sunday what my 4000# turd does off the tbrake with it. On the street it drives like stock....my wife thinks i got rid of my stall
Quick Reply: 4l80e converter not holding 1000rwhp /need help
