Fueling & Injection - Need info on FAST rails, adapter kit, and fittings
OreoLt1
03-21-2008, 11:02 AM
I have been searching through the forum for answers on what exactly you will need to install a set of FAST rails on an 02 Fbody but I have seen multiple aswers and prices.
On thunderracing they have the rails w/hardware and then an adapter kit with a 3/8 push connect coupling for a OEM fuel line to convert it to a -6AN male fuel fitting for use in conjunction with the FAST Fuel Rails.
So with that setup would I need anything else? Plus that setup is around $238 I have read that people have spent upwards of $300+ on all the fittings to adapt the FAST rails to an OE setup. Am I missing something?
Any quick responses along with all responses are very much appreciated! I plan on purchasing the Racetronix pump kit this weekend and if everything works out the rails too since they're having an Easter sale!
warp_6
03-23-2008, 10:51 AM
That will work. I bought mine from WS6 store.
Rails 54023
Install kit FAST-FRK
I also bought a assemble kit from jegs. You will need to cut your own lines and assemble the fittings.
Koul tools 581-468
Jegs 555-28010
BlackThunder02
03-25-2008, 04:09 PM
+1 on Warp 6. Doing the exact same thing with the same components.
Tiger2o69
03-27-2008, 01:22 PM
I have all of it for sale if interested.. let me know..
WS6store.com
03-28-2008, 06:12 PM
We sell a kit that has everything you need to connect to the factory fuel line...available with or without the pressure gauge.
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=2040
